10 years agoNIOS II SPI communication
Hi All! I've a problem with Nios SPI communication. I studied "Embedded Peripherals IP User Guide" but I didn't understand how to use alt_avalon_spi_command() function. I understood that an Avalon...
9 years agoHI fmv,
i'm facing the same problems that you had. I tried both codes you have proposed but i still have several problems to obtain data and retransmitt data back to the Master defined as a microcontroller. I was wondering if you could provide me the entire code that you've used in order to solve the problem or some advices to adopt. Thanks
