14 years ago
Nios II Programmer
Hi all,
I have problem during setting Nios II Flash programmer. The problems are "system ID hash" not found and "system timestamp" not found. what should i do to connect the "system ID hash" and "system timestamp". Do you have any suggestion or idea regarding my problem.
Kindly review the picture attached.
Thanks in advance :)
    Dear Daixiwen,
    I already changed it. But, i still cannot download. Do you have any ideas? :(
    Go into SOPC builder / QSys, double click on the cpu component, and from there you should find atab where you can select the core type, between the /e, /s and /f variants.
    Dear Daixiwen,
    Thanks for your prompt reply. If you dont mind, how to switch from Nios II CPU to Nios II/e core?
    Thanks for your strong support :)
    One of the IPs you are using isn't licensed. You can't flash your design without buying the license first.
    From this line
    Vendor: 0x6AF7, Product: 0x00A2
    It looks like it is the Nios II CPU. Try to switch to the Nios II/e core, that doesn't require a license. (If you are running Quartus II 10 or newer).
    Dear Daixiwen,
    Thank you for your concern. I already solve the problem. But now, there is another problem happen. This error appeared (refer my attachment) when I try to download the ELF file using flash programmer. Do you have any suggestion or idea about that?
    Are you sure you uploaded the correct .sof image to the FPGA first? Does your hardware project include the system ID component?
