14 years agoNios II Programmer
Hi all, I have problem during setting Nios II Flash programmer. The problems are "system ID hash" not found and "system timestamp" not found. what should i do to connect the "system ID hash" a...
14 years agoOne of the IPs you are using isn't licensed. You can't flash your design without buying the license first.
From this lineVendor: 0x6AF7, Product: 0x00A2It looks like it is the Nios II CPU. Try to switch to the Nios II/e core, that doesn't require a license. (If you are running Quartus II 10 or newer).
