14 years agoNios II Programmer
Hi all, I have problem during setting Nios II Flash programmer. The problems are "system ID hash" not found and "system timestamp" not found. what should i do to connect the "system ID hash" a...
14 years agoGo into SOPC builder / QSys, double click on the cpu component, and from there you should find atab where you can select the core type, between the /e, /s and /f variants.
