11 years agonios-ii-on-die-temperature-sensor example
Hi im totally new to FPGA's...Im trying to run the following example. http://www.alteraforum.com/forum/showthread.php?t=19108&highlight=on-die+temperature+sensor+example if i load the...
11 years agohi thanks for the tip on clock freq. In the demo there is one clock source@50MHz
and the Altera Modular ADC core setting are as in the picture. http://www.alteraforum.com/forum/attachment.php?attachmentid=10801&stc=1 and setting from Quartus
nios_setup u0 (
.clk_clk (nios_50M_clk),// clk.clk
.reset_reset_n (reset_n), // reset.reset_n
.led_io_external_connection_export (LED), // led_pio_external_connection.export
.sw_io_external_connection_export (SW), // switch_pio_external_connection.export
.modular_adc_0_adc_pll_clock_clk (adc_10M_clk), // modular_adc_0_adc_pll_clock.clk
.modular_adc_0_adc_pll_locked_export (pll_locked) // modular_adc_0_adc_pll_locked.export
); is there a need for two clock sources ? PLL settings: defparam altpll_component.bandwidth_type = "AUTO",
altpll_component.clk0_divide_by = 5,
altpll_component.clk0_duty_cycle = 50,
altpll_component.clk0_multiply_by = 1,
altpll_component.clk0_phase_shift = "0",
altpll_component.clk1_divide_by = 1,
altpll_component.clk1_duty_cycle = 50,
altpll_component.clk1_multiply_by = 1,
altpll_component.clk1_phase_shift = "0",
altpll_component.compensate_clock = "CLK0",
altpll_component.inclk0_input_frequency = 20000,
altpll_component.intended_device_family = "MAX 10 FPGA",
altpll_component.lpm_hint = "CBX_MODULE_PREFIX=all_pll",
altpll_component.lpm_type = "altpll",
altpll_component.operation_mode = "NORMAL",
altpll_component.pll_type = "AUTO",
altpll_component.port_activeclock = "PORT_UNUSED",
altpll_component.port_areset = "PORT_USED",
altpll_component.port_clkbad0 = "PORT_UNUSED",
altpll_component.port_clkbad1 = "PORT_UNUSED",
altpll_component.port_clkloss = "PORT_UNUSED",
altpll_component.port_clkswitch = "PORT_UNUSED",
altpll_component.port_configupdate = "PORT_UNUSED",
altpll_component.port_fbin = "PORT_UNUSED",
altpll_component.port_inclk0 = "PORT_USED",
altpll_component.port_inclk1 = "PORT_UNUSED",
altpll_component.port_locked = "PORT_USED",
altpll_component.port_pfdena = "PORT_UNUSED",
altpll_component.port_phasecounterselect = "PORT_UNUSED",
altpll_component.port_phasedone = "PORT_UNUSED",
altpll_component.port_phasestep = "PORT_UNUSED",
altpll_component.port_phaseupdown = "PORT_UNUSED",
altpll_component.port_pllena = "PORT_UNUSED",
altpll_component.port_scanaclr = "PORT_UNUSED",
altpll_component.port_scanclk = "PORT_UNUSED",
altpll_component.port_scanclkena = "PORT_UNUSED",
altpll_component.port_scandata = "PORT_UNUSED",
altpll_component.port_scandataout = "PORT_UNUSED",
altpll_component.port_scandone = "PORT_UNUSED",
altpll_component.port_scanread = "PORT_UNUSED",
altpll_component.port_scanwrite = "PORT_UNUSED",
altpll_component.port_clk0 = "PORT_USED",
altpll_component.port_clk1 = "PORT_USED",
altpll_component.port_clk2 = "PORT_UNUSED",
altpll_component.port_clk3 = "PORT_UNUSED",
altpll_component.port_clk4 = "PORT_UNUSED",
altpll_component.port_clk5 = "PORT_UNUSED",
altpll_component.port_clkena0 = "PORT_UNUSED",
altpll_component.port_clkena1 = "PORT_UNUSED",
altpll_component.port_clkena2 = "PORT_UNUSED",
altpll_component.port_clkena3 = "PORT_UNUSED",
altpll_component.port_clkena4 = "PORT_UNUSED",
altpll_component.port_clkena5 = "PORT_UNUSED",
altpll_component.port_extclk0 = "PORT_UNUSED",
altpll_component.port_extclk1 = "PORT_UNUSED",
altpll_component.port_extclk2 = "PORT_UNUSED",
altpll_component.port_extclk3 = "PORT_UNUSED",
altpll_component.self_reset_on_loss_lock = "OFF",
altpll_component.width_clock = 5;
endmodule all_pll alt_pll_inst ( .areset ( reset ),
.inclk0 ( clk ),
.c0 ( adc_10M_clk ),
.c1 ( nios_50M_clk),
.locked ( pll_locked )
); not sure what this is, should it be 50e6(50MHz) ? ? ? altpll_component.inclk0_input_frequency = 20000, /thanks
