11 years agonios-ii-on-die-temperature-sensor example
Hi im totally new to FPGA's...Im trying to run the following example. http://www.alteraforum.com/forum/showthread.php?t=19108&highlight=on-die+temperature+sensor+example if i load the...
11 years agoGot the debugger running...I deleted the projects i had in the workspace and now it seems runnnig...So now i can run code from NIOS-II in debugger mode via JTAG on the eval board :-)
I would like to burn it to flash but im having some problems. when i open the .par file from the on die temp example in Quartus v15, its missing the nios_setup.sip and the nios_setup.qip files so my "start compilation" (CTRL+L) fails in quartus. read about the elf2flash but cant get i to work, the flash programmer in v15 seem's to be missing some bottom compared to this 2-6 in this manual. https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_nios2_flash_programmer.pdf thanks in advance
