11 years agonios-ii-on-die-temperature-sensor example
Hi im totally new to FPGA's...Im trying to run the following example. http://www.alteraforum.com/forum/showthread.php?t=19108&highlight=on-die+temperature+sensor+example if i load the...
11 years agoHi thanks for the reply, that solved the problem... Now everything is building in NIOSII. How ever when i try to run the project i get no messages in the console.
Console: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Initializing CPU cache (if present) OK Downloading 00008000 ( 0%) Downloading 00009824 (94%) Downloaded 7KB in 0.0s Verifying 00008000 ( 0%) Verifying 00009824 (94%) Verified OK Starting processor at address 0x00008180 How to find out whats wrong(guess thats the plan is it goes to 100% ?) The NIOS-II Console is empty... ive been following the section: Steps to run this program (Software) in NIOS_temp_sensor_design.pdf thanks stefan
