nios-ii-on-die-temperature-sensor example for Arria10
Hello, We uses Arria10, thus we need to monitor the A10 on-die-temperature. We prefer to use NIOS II to monitor that. I saw there's nios-ii-on-die-temperature-sensor example for MAX 10.
I just wonder whether there is a similar nios-ii-on-die-temperature-sensor example for Arria 10 ?
Thanks a lot
There's no an example like for the Max 10, but here you have some information about how to use the IP for the temperature sensor, also a tutorial for the same.
Tell me if this works for you!
Documentation: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_alttemp_sense.pdf
Video: https://www.youtube.com/watch?v=80CHimfw5jM
Isaac Vazquez.
- Isaac_V_Intel
Contributor
Did the solution works for you?
Best regards.
- Isaac_V_Intel
Contributor
Isaac Vazquez.
