16 years agoNIOS II IDE V9.1 / Where ?
Hello, I recently tried to shift to V9.1 in the middle of a big project with mild results. I should not tried ... I would like now to work with NIOS II IDE and Quartus II V9.1 (I Need V9.1 f...
16 years ago --- Quote Start --- The NIOS II 9.1 IDE is in the Start-menu under Altera / NIOS II EDS 9.1 / Legacy NIOS II Tools / NIOS II 9.1 IDE Or directly C:\Altera\91\nios2eds\bin\eclipse\nios2-ide.exe Note that 9.1 tools suffer a bug related to EPCS programming. So if your design uses EPCS flash, make sure you first test programming the EPCS flash and make sure your board can load the FPGA code and application before you jump into 9.1 completely ... Jari --- Quote End --- Thanxs a lot Jari. I'm stupid ... Rgds, Thierry
