18 years agoNios II IDE 8.0 SP1 hangs?
Just upgraded to SP1, and now when I try to debug, I end up with Nios II IDE hanging at "launching: (60%)" Is there a bug in the service pack? Anything I should try before I uninstall/reinstal...
17 years agoI'm not sure if this is the problem. But I've noticed in some of the recent versions of the IDE, that it will appear to hang. Every time that it has happened to me, if I look down in the bottom right hand corner of the IDE, I notice that the indexer is running dog slow and blocking everything else from running at the same time. See if it's the same for you. I don't know what is causing the indexer to run so slow but you can change the indexing options so that it doesn't run.
Jake
