17 years agonios ii flash programming error
Hi: When I program *.elf to flash ,there something wrong with it. The infomation like # !/bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be ...
17 years agoNo,Because I test it with one project ,it shows us the information :
cd D:/NIOS_II/SRAM_FLASH/SopcLed/hello_world_small_0/Release # Creating .flash file for the project "$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x00200000 --end=0x3fffff --reset=0x48000 0 --input="hello_world_small_0.elf" --output="cfi_flash.flash" --boot="E:/altera /80/ip/nios2_ip/altera_nios2/boot_loader_cfi.srec" # Programming flash with the project "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x00200000 --instance=0 "cfi _flash.flash" Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK : Checksumming existing contents 00000000 : Reading existing contents Checksummed/read 16kB in 0.4s 00000000 ( 0%): Erasing Erased 16kB in 0.2s (80.0kB/s) 00000000 ( 0%): Programming Programmed 1KB +15KB in 0.3s (53.3KB/s) Device contents checksummed OK Leaving target processor paused //END But when I use other project build by myself,it shows information like: #!/bin/sh # # This file was automatically generated by the Nios II IDE Flash Programmer. # # It will be overwritten when the flash programmer options change. # cd E:/altera/80/workplace/RA8835/hello_world_1/Debug # Creating .flash file for the project "$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x00200000 --end=0x3fffff --reset=0x20000 0 --input="hello_world_1.elf" --output="cfi_flash.flash" --boot="E:/altera/80/ip /nios2_ip/altera_nios2/boot_loader_cfi.srec" # Programming flash with the project "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x00200000 --sidp=0x000010b0 --id=148608136 --timestamp=1252506938 --instance=0 "cfi_flash.flash" Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x000010B0: verified : Checksumming existing contents 00000000 : Reading existing contents 00004000 : Reading existing contents 00006000 : Reading existing contents Checksummed/read 5kB in 0.1s 00000000 ( 0%): Erasing 00004000 (50%): Erasing 00006000 (75%): Erasing Erased 32kB in 0.7s (45.7kB/s) 00000000 ( 0%): Programming 00004000 (50%): Programming 00006000 (75%): Programming Programmed 28KB +4KB in 0.5s (64.0KB/s) Verify failed at offset 0 Verify failed at offset 4000 Verify failed at offset 6000 Leaving target processor paused //END
