17 years agonios ii flash programming error
Hi: When I program *.elf to flash ,there something wrong with it. The infomation like # !/bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be ...
17 years agoObviously the NIOS isn't able to program the flash.
Either: 1 - The interface to the flash is bad (like incorrect connections, pin assignments, not meeting timing, bad timing parameters etc.) 2 - The flash is write protected. 3 - The flash is corrupt. Jake
