Nios II example running on A10 GX dev kit.
- 3 years ago
Here is the link to the Hello World Design Example flow for your reference:
http://www.ee.nmt.edu/~erives/531_14/tt_my_first_nios_sw.pdf
Hope this could help/
Thank you.
Kelly
The design example is designed specifically based on Quartus 15.1 pro version and therefore if a different version is used, user is expected to be familiar with the IP upgrades.
Flashing the .hex file will be via EPCQ flash for Arria10 GX as shown as the picture below of the A10GX Block diagram.
You may refer to this link to look at the EPCQ booting flow and information: https://www.intel.com/content/www/us/en/docs/programmable/683104/current/nios-ii-processor-booting-from-altera.html
Hope this helps. Thank you.
Kelly
Hi David,
Here is the block diagram of the Arria10GX for you to understand more:
Hope this will help to clear your doubts.
Thank you.
Kelly
