mjobbeh
3 years agonios fpga
We are working on a Nios system targeting a DE2-115 kit. When running the code on SDRAM (Run As -> Nios II Hardware), the code is executed in the required speed, but when loading the code from EPCS m...
hareesh
3 years agoHi,
please check your linker scripts, because there you can select the where you have to execute the code. so once check in your linker script.
mjobbeh
3 years agoI tried all Linker script options, but i had the same problem,Does the schematic of de2-115 board or the size of code affect the load of code from EEPROM.
