17 years agoNintendo DS Passthrough
Hiya, I'm trying to build a simple Nintendo DS card passthrough (also known as a "PassMe") -- basically use the FPGA as a man in the middle between the DS and DS card communication. I've writte...
17 years ago --- Quote Start --- i'm not a Verilog guy but it doesn't look like you register card logic which could cause problems like this. how fast does the DS data run? --- Quote End --- What do you mean with I don't register card logic? The DS clock runs at approx 6.7 MHz. --- Quote Start --- you specify inout [7:0] DSCARD0_DAT; as an 8 bit bidir signal you correctly used assignments for that, but only for 6 bit [5:0] and no assignment for bit 6 and 7 so you can combine these lines as assign DSCARD0_DAT[7:0] = (DSCARD0_RES & ~DSCARD0_RCS & ~IsCommand ) ? DSCARD1_DAT[7:0] : 8'bzzzzzzzz; assign DSCARD1_DAT[7:0] = (DSCARD0_RES & ~DSCARD0_RCS & IsCommand ) ? DSCARD0_DAT[7:0] : 8'bzzzzzzzz; your problem no starts here where you try to switch the direction from card0 to card1 and vice versa with a registered signal. this is some kind of an asynchron dataloop, hard to dig down the problem. i have no information about how hard the timing must be in this application but if possible try to write a fully synchronus design and pipe some of the signals that the or clock synchron to each other. --- Quote End --- Yeah the reason for the seperate DSCARDx_DAT[] lines is that I was testing the signals one-by-one, while leaving 6 and 7 directly connected between CARD0 and CARD1. What do you mean the problem is with the registered signal? Could you explain this some more? How would a fully synchronous design look like? Thanks in advance
