13 years agoNichestack Tutorial Using Arria V GX starter board
Hi all, Has anyone tried/succeeded in completing the nichestack tutorial provided on Altera's website using the Arria V GX starter board? I have been working at it for a couple weeks now, ...
13 years ago --- Quote Start --- I got the system running by using sram. system clock is 50MHz. however when I want to increase the frequency it fails. I modified based on stock remote update program. --- Quote End --- Hi sunxishan, thank you for your reply. When you say you got the system running, do you mean the simple socket server using an Arria V GX starter board? And if so, what do you mean by the stock remote update program, and where did you make modifications (qsys files, quartus VHDL files, etc.) My system actually uses 3 clocks: 100 MHz for the DDR3 memory, 125 Mhz for the ethernet system, and 50 Mhz for everything else (all based on what I read in the Arria V GX starter kit reference manual). Thank you
