17 years agonewbie question - gpio
Hello everyone, I have an altera DE2 Board and have a question regarding the gpio. As I only used the onboard input debvices(switches/buttons) up to now I'm not sure how to connect something to ...
16 years agoHello,
no clue about what FlexRay is but.. The GPIO pins on a DE2 are 3.3V powered, so they can act as 3.3V LVCMOS/LVTTL pins. They can be in, out or inout pins, with optional tri-state or open-drain function. And a few other things. That is to say, those pins can implement pretty much anything that uses 3.3V LVCMOS/LVTTL levels. But if you need something else than 3.3V, you need a transceiver. There are SPI cores. Maybe there's a FlexRay core as well.
