17 years agonewbie question - gpio
Hello everyone, I have an altera DE2 Board and have a question regarding the gpio. As I only used the onboard input debvices(switches/buttons) up to now I'm not sure how to connect something to ...
17 years agoAs long as the voltage levels and so are ok, you can simply connect the node to the GPIO pins. From the Altera device, these pins will be seen normally (like the SW and the pushbuttons you already worked with).
