14 years agoNewbie - Where to put my Time/Energy
Hi All, I am new to FPGAs with a strong background in embedded micros. I have a new project where an FPGA would be a good fit. I have started into the FPGA world having: Installed Quartu...
14 years ago --- Quote Start --- How fast (clock rate) and what signal processing are you doing with the data? Dave --- Quote End --- That is to be determined. The data will be IQ data from an RF front end and I am not sure what processing will be required. The ADCs will run between 15-20 MSPS. --- Quote Start --- Since you have a background in micros, this is probably a good place to start. Though you do not need to have a NIOS II processor as a master. The JTAG-to-Avalon-MM bridge allows you to read and write from an FPGA design via the USB interface. Dave --- Quote End --- This is good to know. I think I will try to get the UART working first without the NIOS uC. How would reccommend proceeding? SOPC tool to try to incorporate the UART with the JTAG-to-Avalon-MM bridge? Does that even make sense? --- Quote Start --- Learn how to use Modelsim, and learn how to write testbenches. You should use Modelsim and a testbench to check that each of the components you design work, and then integrate them into a larger system and check that they work there. The Avalon master can be your NIOS core, or it can be the Avalon-MM BFM (bus functional model - a simulation only component). Dave --- Quote End --- OK, I have work to do. I am flying solo on this project and it is way overwhelming. Thank you! Rich --- Quote Start --- If you get stuck, just ask questions. Cheers, Dave --- Quote End ---
