9 years agonew to NIOS II. Need help for my requirement.
I am using Altera Arria V GX FPGA, 5AGXMA5G4F35C5N. I would like to run NIOS soft core in this FPGA. I would like to have Ethernet 100MB and M.2 PCIe x 4 interfaces. I am hardware engineer hence I...
9 years agoHi,
can any body help me. i'm working with altera university program DE4 board, i'm using NIOS II to commande the transfer of data from FPGA to My SD_Card. While building my projet within Eclipse this error appear. need your help!! Info: Linking TestSD.elf nios2-elf-g++ -T'../TestSD_bsp//linker.x' -msys-crt0='../TestSD_bsp//obj/HAL/src/crt0.o' -msys-lib=hal_bsp -L../TestSD_bsp/ -Wl,-Map=TestSD.map -O0 -g -Wall -mno-hw-div -mhw-mul -mhw-mulx -mgpopt=global -o TestSD.elf obj/default/hello_world.o -lm -msys-lib=m c:/intelfpga/17.1/nios2eds/bin/gnu/h-x86_64-mingw32/bin/../lib/gcc/nios2-elf/5.3.0/../../../../../H-x86_64-mingw32/nios2-elf/bin/ld.exe: TestSD.elf section `.text' will not fit in region `onchip_memory2_0' c:/intelfpga/17.1/nios2eds/bin/gnu/h-x86_64-mingw32/bin/../lib/gcc/nios2-elf/5.3.0/../../../../../H-x86_64-mingw32/nios2-elf/bin/ld.exe: address 0x1d92c of TestSD.elf section `.rwdata' is not within region `onchip_memory2_0' c:/intelfpga/17.1/nios2eds/bin/gnu/h-x86_64-mingw32/bin/../lib/gcc/nios2-elf/5.3.0/../../../../../H-x86_64-mingw32/nios2-elf/bin/ld.exe: address 0x1fd48 of TestSD.elf section `.bss' is not within region `onchip_memory2_0' c:/intelfpga/17.1/nios2eds/bin/gnu/h-x86_64-mingw32/bin/../lib/gcc/nios2-elf/5.3.0/../../../../../H-x86_64-mingw32/nios2-elf/bin/ld.exe: address 0x1d92c of TestSD.elf section `.rwdata' is not within region `onchip_memory2_0' c:/intelfpga/17.1/nios2eds/bin/gnu/h-x86_64-mingw32/bin/../lib/gcc/nios2-elf/5.3.0/../../../../../H-x86_64-mingw32/nios2-elf/bin/ld.exe: address 0x1fd48 of TestSD.elf section `.bss' is not within region `onchip_memory2_0' c:/intelfpga/17.1/nios2eds/bin/gnu/h-x86_64-mingw32/bin/../lib/gcc/nios2-elf/5.3.0/../../../../../H-x86_64-mingw32/nios2-elf/bin/ld.exe: region `onchip_memory2_0' overflowed by 93512 bytes collect2.exe: error: ld returned 1 exit status make: *** [TestSD.elf] Error 1
