13 years agoNest if statement in case statement
Is it customary and synthesizable to use nested 'case' statement inside the 'if' statement? Tnx5 Replies
Thanks to all :)
--- Quote Start --- Tnx for quick response. The "No it is not" answer refers to customary or synthesizable or both of them? Tnx --- Quote End --- There is no problems using Case inside If or If inside case. It depends what you are doing, and what you expect from the circuit. - Altera_Forum
--- Quote Start --- Tnx for quick response. The "No it is not" answer refers to customary or synthesizable or both of them? Tnx --- Quote End --- unfortunately I disgree with the "no..." from fpga_guru011. The main differences are to do with priority issues. the case statement is equivalent to multiple parallel ifs. Most of everyday code is made up of " if" or "case" inside each other. if rising_edge(clk) then if enable = '1' then case .... when .... if... end if; end case; end if; end if; - Altera_Forum
The "No it is not" answer refers to customary or synthesizable or both of them? Tnx - Altera_Forum
--- Quote Start --- Hi, Is it customary and synthesizable to use nested 'case' statement inside the 'if' statement? Tnx --- Quote End --- No it is not , but it dosent make any sense why would anyone use "case" inside a "if" when you can use elsif multiple times . for example: Interfacing_ADC_DAC: PROCESS(sys_clk, reset_n) BEGIN IF reset_n = '0' THEN ADC_data_A <= (others=>'0'); ADC_data_B <= (others=>'0'); -- DA <= (others=>'0'); DB <= (others=>'0'); -- LEDG(1 downto 0) <= (others=>'0'); -- 1st Condition ------------------- ELSIF SW(4 downto 2) = "011" THEN LEDR(2 downto 0) <= "001"; ADC_data_A <= ADA_D; ADC_data_B <= ADB_D; ---------------- -- DAC is connected to an Up-Counter DA <= Count; DB <= not(Count); -- 2nd Condition ------------------- ELSIF SW(4 downto 2) = "010" THEN LEDR(2 downto 0) <= "010"; -- ADC output is connected directly to DAC DA <= ADA_D; DB <= ADB_D; -- 3rd Condition ------------------- ELSIF SW(4 downto 2) = "001" THEN LEDR(2 downto 0) <= "100"; -- DAC is connected to a NOC output DA <= nco_sin_out + OFF_set; DB <= nco_sin_out + OFF_set; -- 4th Condition ----------------<< FIR Filter ELSIF SW(4 downto 2) = "101" THEN LEDR(2 downto 0) <= "100"; -- ADC is connected to FIR Filetr ast_sink_data <= ADA_D; ADC_data_B <= ADB_D; -- DAC is connected to a NOC output DA <= ast_source_data; DB <= not(Count); ------------ END IF; END PROCESS;
