17 years agoNEEK VGA Module
[attachment=194:NEEK_VGA.zip][attachment=194:NEEK_VGA.zip][attachment=194:NEEK_V
GA.zip]neek_rgb_vga.vhd is the VHDL module. The module accepts parallel RGB plus HV syncs with DATA Enable and a clock that is three (3) times the RGB pixel rate and outputs a NEEK VGA TDM data stream with syncs and enables. The ZIP contains a QuartusII Archive and will build a small test example of an instantiation of the "NEEK_RGB_VGA" module. Save off the SOF file before you rebuild so that you can see what it does, before you try to build it. *** Built with QuartusII v9.0 (sp1) and uses the Test Pattern Generator and Clocked Video Output from the Video IP to generate a video stream. (A copy of this example project is in the Hardware Projects group, also) *** Note: Archive missing .SOPC file (Added to ZIP on 7/17/09 )No RepliesBe the first to reply
