17 years agoNEEK version of InterNiche Superloop example for 9.0sp1
I have recently posted a NEEK version of this superloop example to the Nios Wiki, please follow the link below.
superloop simple socket server plus (http://www.nioswiki.com/exampledesigns/superloopsimplesocketserverplus) - This is a SUPERLOOP implementation of the Simple Socket Server Plus application. In this example the application is compiled with the InterNiche Stack running in superloop mode, without an RTOS.3 Replies
Thank you very much. it makes it more understood.
But now I am facing to inclusion problems. I try to "fix". A lot of tedious work : Add all new includes paths in project properties (specifically in build properties) clic, clic, clic, add..., clic, paste, enter, ... reclic, clic, ........:mad: Do it again for "Debug" Add Defined SUPERLOOP in Build properties. Do it again for "Debug" ....:eek: :confused: :huh: :lol: - Altera_Forum
IIRC the IDE prevents you from enabling the Interniche TCP/IP stack without the RTOS. But if you want to run in superloop mode you must disable the RTOS, and the only way to do that with the TCP/IP stack still enabled is to manually edit the system library system.stf file.
Hi, very interesting.
I want to build my own superloop ethernet software for NIOS II. No server yet. Some very basic transferts. I have a few questions : Are you obliged to activate the RTOS in system library properties in NIOS II IDE even if RTOS is not used ?
