17 years agoNEEK version of InterNiche Superloop example for 9.0sp1
I have recently posted a NEEK version of this superloop example to the Nios Wiki, please follow the link below. superloop simple socket server plus (http://www.nioswiki.com/exampledesigns/super...
17 years agoIIRC the IDE prevents you from enabling the Interniche TCP/IP stack without the RTOS. But if you want to run in superloop mode you must disable the RTOS, and the only way to do that with the TCP/IP stack still enabled is to manually edit the system library system.stf file.
