15 years agoNeed urgent help with deciding BUS or NODE for the input!!
Hi I'm trying to take 10 individual bits from a 10-bit parallel adc and do some processing on it in a FPGA, but I'm confused about how to implement it in the system. Should I use a bus (10bit wide) ...
15 years agoYes you should use a bus. The blocks that you use should be able to process a vector input instead of just individual bits.
