14 years agoneed some VHDL code help
I am trying to program my board so when you press the ARM and Launch button it will start up my motor. The code not done yet, but I am stuck on getting the counter to work. here what I have ...
14 years agowow thank you for all your help, I almost have it now i think.
here is my new codeLIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY countdownflying IS
PORT(
clk : in std_logic;
Abort : in BIT;
ARM : in BIT;
Launch: in BIT;
q : BUFFER INTEGER RANGE 0 TO 11;
twosegment7 : out std_logic_vector(14 downto 0));
END countdownflying;
ARCHITECTURE arc OF countdownflying IS
BEGIN
PROCESS (clk,ARM,Abort)
BEGIN
IF (ARM='0' OR Abort='1') THEN
q <= 0;
ELSIF (clk'EVENT AND clk='0') THEN
q <=q-1;
case q is
when 0 => twosegment7 <="000000001111110"; -- '0'
when 1 => twosegment7 <="000000000110000"; -- '1'
when 2 => twosegment7 <="000000001101101"; -- '2'
when 3 => twosegment7 <="000000001111001"; -- '3'
when 4 => twosegment7 <="000000000110011"; -- '4'
when 5 => twosegment7 <="000000001011011"; -- '5'
when 6 => twosegment7 <="000000001011111"; -- '6'
when 7 => twosegment7 <="000000001110000"; -- '7'
when 8 => twosegment7 <="000000001111111"; -- '8'
when 9 => twosegment7 <="000000001111011"; -- '9'
when 10 => twosegment7 <="001100001111110"; -- '10'
when 11 => twosegment7 <="100011101110111"; -- 'LA'
--nothing is displayed when a number more than 9 is given as input.
when others=> twosegment7 <="011111111111111";
end case;
else
END IF;
END PROCESS;
END arc;
It still showing me numbers above 11, not sure why.
