14 years agoneed some VHDL code help
I am trying to program my board so when you press the ARM and Launch button it will start up my motor. The code not done yet, but I am stuck on getting the counter to work. here what I have ...
14 years ago --- Quote Start --- q : BUFFER INTERGER RANGE 0 TO 11; --- Quote End --- should be q : BUFFER INTEGER RANGE 0 TO 11; --- Quote Start --- q <= q+1 --inputs equation --- Quote End --- should be q <= q+1; --inputs equation --- Quote Start ---
process (clk,bcd)
BEGIN
IF (Abortd = '1') THEN
process (clk,bcd)
BEGIN
if rising_edge(clk) then -- Assuming rising edge
end if; -- Don't forget to add one more end if to match the added 'if rising_edge(clk)
--- Quote Start --- case q is when '0000'=> onesegment7 <="000000001111110"; -- '0' when '0001'=> onesegment7 <="000000000110000"; -- '1' etc. --- Quote End --- should be case q is when 0 => onesegment7 <="000000001111110"; -- '0' when 1 => onesegment7 <="000000000110000"; -- '1' etc. Kevin Jennings
