15 years agoNeed some help to use altdq and altdqs megafunction.
Hi, I am working on memory controller. In that data received from memory is edge aligned with clock. I want to give phase shift of incoming clock to 90 degree so that I can receive data cent...
15 years agoSo you want to make your own memory Phy? Most (if not all) of the top reputation holders will warn you that is a challenge. I too believe it is.
To answer your question: Yes, using altdq and altdqs is one way to go. Now If you are using altdq and altdqs you are getting near the complexity of Altera's Altmem_Phy. There are other solutions depending on your requirements on the memory speed and number of chips, or DIMMs, involved. Is there a particular reason you want to roll your own?
