17 years agoNeed "repeater/buffer" for AS config of multiple Cyclone iii slaves
As it states on page 10-14 of the Cyclone III device handbook: "When cascading Cyclone III devices in multi-device configuration, you must connect repeater buffers between the Cyclone III master and ...
17 years agoThe output resistance recommendation is misleading in so far, as you won't most likely find no fast buffer with a that high output impedance. Provide a series termination resistance and adjust it for sufficient low overshoot. You should use the lowest acceptable resistance value to minimize delay. I think, fast single gate LVCMOS buffers are a good option, e.g. LVC1G34, they have an internal output impedance of about 25 ohms.
