16 years agoneed help with some vhdl syntax
Hi, there: I have been working with niosII for days. When I checked the vhd files that SOPC builder generated, I found some syntax that I had never encountered. They were: 1. ...
16 years agostd_logic' and std_logic_vector' is not a type conversion, it is a type qualification.
If I have the following literal: "110100101", it could be a string, it could be a std_logic_vector, it could be a bit_vector etc. Similarly, '0' and '1' could a character or a std_logic value. This can be a problem, especially with functions with multiple definitions that take different types. The most common one is the write procedure from textio. If I have the following line: write(my_line, "110101"); The compile has no idea if Im trying to write a string or a bit_vector, and will throw an error. To fix it you write: write(my_line, string'("110101")); and this tells the compiler that it is a string you meant, rather than a bit_vector. if you leave the ' out, it is a type conversion.
