16 years agoneed help with some vhdl syntax
Hi, there: I have been working with niosII for days. When I checked the vhd files that SOPC builder generated, I found some syntax that I had never encountered. They were: 1. ...
16 years agoYou are correct - the ' is a way of "casting" - converting the type to std_logic or std_logic_vector. You are also right that it is probably redundant. Try compiling without the casting?
