16 years agoNeed help to design SOPC gui
I have designed one custom component.In that I am using reconfigurable PLL. It's working is different for different device families. So I want to derive device family as a parameter for my design.Is it possible? One more thing how to add tab(button) in SOPC for custom component.Please give some example if possible? Thanks in advance Regards, Krupesh2 Replies
Thank you Jake.
I got the answer of my first question from the pdf.In pdf it is mentioned that how to add button(using add_display_property) however I did not get it. So could you please give me a simple example for the same ? Thanks again, Regards, Krupesh - Altera_Forum
Refer to chapter 7 of the SoPC Builder Handbook:
http://www.altera.com/literature/hb/qts/qts_qii5v4_01.pdf You can get pretty fancy with the regular TCL script. If you want to go beyond what the TCL scripting provides, you'll have to write your own external program. Jake
