15 years agoNeed help regarding RAM initialization
Hello, I am working on a music player project and would like to preload some songs onto a DE2 board and play them back using eg. KEY's on the board. I am very much a beginner so please be patie...
15 years agoThanks for your response rbugalho.
My sound files are quite small, relatively speaking. I will nevertheless need to sample at a much lower rate than I had intended. I'm trying to avoid the use of USB or SD card. I think I have found tools to convert between WAV/PCM and .HEX, so I will try to use that to initialize the memory and go from there.
