16 years agoneed help of the readmemb function in verilog
Hi, I wrote a code to read data from a .txt file and output the data to the AD/DA card. But the output of the module is a constant value. (the text file has 8192 binary numbers with different ...
16 years agoThanks for your kindly help. The code works well.
BTW, I find it also works if I remove the "for" loop, just use readmemb function once. Thanks a lot for your suggestions. Regards, Lyila
