16 years agoneed help of the readmemb function in verilog
Hi, I wrote a code to read data from a .txt file and output the data to the AD/DA card. But the output of the module is a constant value. (the text file has 8192 binary numbers with different ...
16 years agoThanks for your help, loywong.
I'll test the code to see if I can get the correct output. If I need to output the data repeatedly, how can I change the code? Thanks again.
