15 years agoNeed help in schematic design (IMPORTANT)
Hi, I am designing cyclone3 FPGA board.In which it has ADV7123 intefacing. i am planning to MUX some of the basic peripherals such us led, seven segment display with data pin of ADV7123. exa...
15 years agoI mean the effect of extra load on the signal could lead to slower step response, especially if you have a load which sinks much more current than a logic port, like a LED does. Besides, longer or branched traces can lead to signal overshoot or ringing.
Those are usually not a great problem if you work at low frequencies, up to a few MHz but you must pay attention if you plan to drive the interface in the tens of MHz range. Please note that I don't know how are you going to connect the ADV7123 device. I assumed you DO actually have leds and 7seg display connected in parallel to the interface signals. Maybe I missed the point and you are simply keeping the original signal names but no led is anymore there. Cris
