16 years agoNeed help from Guru
Hey guys, I am looking for some help in the syntax. Following is my syntax to perform a voting system. Library IEEE; USE IEEE.std_logic_1164.all; Entity Gproject IS PORT ( Se0, S...
16 years agoThe code that you showed doesn't have any H1 instantiation.
The most likely cause is that you forgot to declare the H_adder component in your architecture.
