16 years agoNeed help from Guru
Hey guys, I am looking for some help in the syntax. Following is my syntax to perform a voting system. Library IEEE; USE IEEE.std_logic_1164.all; Entity Gproject IS PORT ( Se0, S...
16 years agodo you guys mind telling me how should I compute the syntax for this part?
BTW... I deleted the X(3) <= '0' then tried to compile... NOW... new problems... Error: Node instance "H1" instantiates undefined entity "H_adder" (H_adder is one of the component I use in the blocks) May I know what this means? Thanks
