15 years agoNeed help for VHDL recursive function
Hi! I'm new to advance VHDL programming. Here below is my code for generating hermite plolynomial (hp). It can be defind recursively like below. hp(k, t) = 1 when k = 0, hp(k, t) = 2*t w...
15 years ago --- Quote Start --- heres a quick example: f = (a * b) + (c * d). It has a latency of 2 clock cycles (ie. result F appears 2 clocks after A,B,C and D inputs. You can put in 1 input every clock cycle, and result is produced every clock cycle)
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity func is
port (
clk : in std_logic;
a,b,c,d : in unsigned(7 downto 0);
f : out unsigned(16 downto 0)
end entity func;
architecture rtl of func is
signal AxB, CxD : unsigned(15 downto 0);
begin
process(clk)
begin
if rising_edge(clk) then
AxB <= a*b;
CxD <= c*d;
f <= ('0' & AxB) + ('0' & CxD);
end if;
end process;
end architecture rtl;
And heres the circuit diagram: --- Quote End --- Tricky, I simply got the point. So nicely explained. I really thank you.
