17 years agoneed help for my project
below is given restoring method code and its algo(its link) there is no error in the programme but output is not comming right please any one can give me hint why it is not coming right lib...
17 years agoHi Anupamasia,
Your code looks like a C-program written in VHDL. You will need to forget about C-style completely and think of RTL, registers in hardware...etc. Here are some notes: 1) input a is in effect doing nothing. 2) there is no clock in your design and so no rgisters yet synchronous design is the backbone of all fpga design today. You are asking for a shift and this requires clocked registers... 3) with multiple sequential assignments in a process only the last one is taken in by the compiler to update the node. Any assignments before that are ignored at compile time. 4) the loop in your program will do nothing like shift because it is simply sequential assignment to same nodes. The expression: rem1<=rem1(3 downto 0) & quo(3); is ok by itself in a clocked process without the loop... kaz
