need alternative for "EP2C15AF256I8N"
Can anyone please suggest an alternative for "EP2C15AF256I8N" with the same package?
- Farabi_Altera
regards,
Farabi - Farabi_Altera
You may want to refer to this link : https://cdrdv2.intel.com/v1/dl/getContent/654376?explicitVersion=true
Check Table 1-3.
You can check with distributors if the replacement part number is available.
regards,
Farabi - ak6dn
Well, the Quartus 13.0sp1 (supports CycloneII device family) has a number of smaller/larger cell count devices that are footprint compatible.
Depends on if you want to stay in the same (now EOL/obsolete) device family.
I doubt you will find any newer devices CycloneIV/V/10 or MAX5/10 that are drop-in footprint compatible.
That will take a bunch of work on your part reading data sheets and comparing device pinouts.
Unfortunately the Quartus migration tool does not help very much when going between device families.
- sainadh52
I need a drop-in compatible pinout also.
- ak6dn
Just the same package, or do you want a drop-in compatible pinout also?
Have you looked at the device migration tool in Quartus?
