17 years agoNeed advices on FPGA for telecom apps
Hi, I'm new to these forums so please let me know if this is the wrong place to post. I'm also quite new to the FPGA world (I've been using for 1 month a DE1 evaluation board with an Altera's ...
17 years agoOk, thanks again for the info.
Up to now I've never used the PLLs of my FPGA but it looks like I really need to learn how to use them :) I'm now searching the "best buy" board among the DSP development kits of Altera; as you say I should have a raw idea of the resources required by the internal design of my project; since I have the project written as a MATLAB script, I'd first need to convert it to a Simulink model however. AFAIK in fact, most telecommunication projects are developed using Simulink and then the Simulink => HDL coder => Quartus II chain. Could anyone confirm/deny this? Another question which arises is: how to efficiently debug the board? For example if I create a program which takes data from the A/D, elaborates it and then stores it into memory, how can I read from a computer that memory, to test if the processing was ok? Reading e.g. the "Cyclone II DSP Development Board reference manual", I see that for this scope, there are basically: - the USB-blaster cable connector (JTAG): in my DE1 board I never managed to use that for debugging, only for programming. From the reference manual it seems it's possible to use it as a general-purpose FPGA<->PC channel up to 1Mbps, instancing a specific IP core. Is it a good solution (i.e. something used in practice) for e.g. inspecting the board's memory contents? - the Mictor connector: this seems to be useful only for logic analyzer usage... - ASI connector: this one seems dedicated to programming only. Thanks again for any precious hints! Francesco
