13 years agoNeed Advice - First time PCIe device development + QSYS
I appreciate any advice/reading materials you can suggest to clarify my issues. I am developing a StratixV-based PCIe card. The card was developed by another company, but they have provided all...
13 years agoHi Evgeni,
--- Quote Start --- Just to clarify that we're talking about Endpoint, not PCIe Root device. --- Quote End --- Yes, the use-case I was considering was an "intelligent" PCIe peripheral device that needs to perform high-performance transactions between itself and a host (root complex). Since high-performance is required, the peripheral device needs to support being a bus master/initiator, and perform burst transactions over the PCIe bus. Typically such an interface is implemented using a DMA controller that has one address in whatever is native for the peripheral logic, eg., 32-bit Avalon-MM addresses, another address for the 64-bit PCIe bus, and a direction bit indicating whether the burst is to or from the PCIe bus. --- Quote Start --- In this particular design PCIe is Avalon-MM master. 24-bit address is calculated automatically by Qsys system builder; it probably looks at the highest address of all connected Avalon-MM slaves. --- Quote End --- Sorry, this comment is not clear. "PCIe is Avalon-MM master" implies that the peripheral board is a PCIe target, where the PCIe transactions are converted by the Qsys PCIe bridge into Avalon-MM transactions. In this case the host accesses the board via the BAR registers, and the 24-bit address translation window discussed above has nothing to do with the transaction. The 24-bit address above configures the width of the TXS Avalon-MM slave/PCIe master. Avalon-MM accesses to that 16MB range get translated into 64-bit PCIe accesses, where the LSB 24-bits are the same as the Avalon-MM address bits, but the (64-24)= 40-bits MSBs are determined by a pseudo-static register setting in the Qsys PCIe bridge control registers. The 40-bit MSBs are pseudo-static in that an SGDMA controller on the Avalon-MM bus cannot easily change the 64-bit PCIe addresses (the scatter-gather list would require 'extra' entries to write a new 40-bit address to change the PCIe MSBs). --- Quote Start --- I didn't have a chance to deal with the case you described. The "worst case" design is 64-bit PCIe Endpoint connected to an embedded processor (PCIe Root) + DMA. So we can control memory allocation scheme on that processor. --- Quote End --- In what way is this a worst-case? (just so that I understand) Cheers, Dave
