16 years agoNeed a ready made DSP that is similar to an OSD
I need a product similar to this OSD pictured below except I need to be able to program it to do things like pixel comparison between 2 frames and pixel modification etc. the product below is just a ...
15 years ago --- Quote Start --- I'd start from an Altera development kit anyway. This gives you a (debugged) schematic you can start with. You create a Quartus project with just inputs and outputs and minimal processing in between. You then see what you need and the strip the schematic (carefully). You can have the layout of the PCB done while you develop the HDL etc. I guess you should be able to buy in a tailored PCB in Qty. 100 at around EUR 125,- (or better). --- Quote End --- which dev kit? can you link to it? i need something that has the giant support/code base that arduino has but with enough power to handle image processing. by image processing I mean simple things like motion detection and color tracking. Just like CMUcam but more powerful.
