11 years agoNAND flash programming model
Hi I use Cyclone V HPS on our custom board and try to work with NAND flash controller. The application is baremetal and hwlib is used. For now I can read device and manufacturer ID and do initiali...
11 years agowell... I have successfully programmed and am able to read the values from nand flash. But after programming when i check the status whether it is successfully programmed or not, the status register shows there is some error in programming. This happens only when I enable ECC. If I disable the ECC it works cool!
