Name of a library that holds the Native PHY IP
- 7 years agoHi SKon1, Just would like to check with you if you have had a chance to look into the <Native PHY>.qip file which was generated after you instantiate the Native PHY IP to see if it is something you are looking for? Inside this file you will find all the required HDL files to be compiled for the Native Phy to work Please let me know if there is any concern. Thank you. Best regards, Chee Pin
Hi SKon1,
As I understand it, you have some inquiries related to the AV Native PHY. Sorry as I am not really familiar with VHDL coding but I will try my best to address your inquiries.
Based on my understanding on your initial description, you seems to be inquiring about the library used to compile the AV Native PHY. Please correct me if I am wrong, as I understand it, there are a number of files or libraries that need to be compiled for Native PHY. It is unlike primitive IP which only require a single file or library. When you instantiate the AV Native PHY, the Megawizard will help to generate a number of HDL files required to be compiled for the Native PHY. You may try to refer to the <Native PHY>.qip file which specify all the required HDL files to be compiled to see if you can find something helpful specific to your requirement.
Chee Pin
