12 years agomy laptop cant recognize USB blaster even in device manager.
I have a problem regarding the DE2 board. I got 1 DE2 board borrow from my faculty, when i wanna load some program into the DE2 board then i realized that there is no USB blaster detected even in dev...
12 years ago --- Quote Start --- My DE2 everything seems normal except cant detect the USB blaster. --- Quote End --- Did you look at the schematic and the user manual? According to the user manual: --- Quote Start --- Turn the RUN/PROG switch on the left edge of the DE2 board to RUN position; the PROG position is used only for the AS Mode programming --- Quote End --- So do you have the selector in the RUN position? Cheers, Dave
