12 years agomy laptop cant recognize USB blaster even in device manager.
I have a problem regarding the DE2 board. I got 1 DE2 board borrow from my faculty, when i wanna load some program into the DE2 board then i realized that there is no USB blaster detected even in dev...
12 years ago --- Quote Start --- There is nothing recognized by my laptop, sadly to say that i tried another DE2 board then its work. --- Quote End --- Ok. It does not sound like this is a USB-Blaster issue, but a DE2 board issue. I'm pretty sure the FTDI chip is powered by the USB interface, so it should always be detected. You should look at the schematics of the DE2 board to be sure. --- Quote Start --- However, my DE2 board blue colour LED on LOAD keep light up but my friend DE2 board no. --- Quote End --- The blue LED from the USB-Blaster indicates that the output enable bit has been set in bit-mode. It will not be on until the USB-Blaster is detected and in-use. --- Quote Start --- i dun know that indicate what. i think is the blaster port problem. Now i am in terrible mood due to this DE2 is borrowed from my University. anyways , thx for ur comment^^ --- Quote End --- Does anything happen with your DE2 board? Eg., does a default program load and start blinking LEDs or something? Perhaps there is a power supply issue. If the MAX II asserts the reset on the FTDI device, then it will not show up on your laptop. Use a voltmeter and probe some of the voltages on the GPIO header and see if they are all present. Cheers, Dave
