17 years ago
My FPGA is not detecting the XOR edge..
I have this verilog code, which depends on either the posedge of the clock or the XOR of my data with its delayed version.
assign x1 = data;
assign x2 = ~x1;
assign x3 = ~x2;
assign XORData = x3 ^ data; //x3 XOR data
always @(posedge clock or posedge XORData) begin
end
my FPGA is not responding to the XOR results. I feel the edge is not occuring or its occuring very very fastly, eventhough simulation is OK.
Whats the problem here?
How do u suggest I write a replacement code?
    A Verilog assign surely causes no delay, it defines an alias signal in logic synthesis. It would require a /* synthesis keep = 1 */ attribute for the wire signals to physically synthesize logic cells. But you most likely need more than two logic cells to build a usable delay line.
    --- Quote Start ---
    If X2 = NOT data
    and X3 = NOT X2
    Then X3 = data
    it follows that ...
    X3 ^ data = data ^ data = 0 for all cases.
    There is no XOR edge because you are merely XORing data with itself.
    Jake
    --- Quote End ---
    True. Except that I am XORing my data with its DELAYED version. The above inversion procedures act as a delay. So that finally I XOR my data with delayed version of data. Such XOR will give me a 1 whenever there is an edge transition in my data.
    But this is not working on FPGA. Not sure why.
    I am working at 40MHz by the way.
    If X2 = NOT data
    and X3 = NOT X2
    Then X3 = data
    it follows that ...
    Jake
