17 years agoMy FPGA is not detecting the XOR edge..
I have this verilog code, which depends on either the posedge of the clock or the XOR of my data with its delayed version. assign x1 = data;
assign x2 = ~x1;
assign x3 = ~x2;
assign XORData =...
17 years ago --- Quote Start --- If X2 = NOT data and X3 = NOT X2 Then X3 = data it follows that ... X3 ^ data = data ^ data = 0 for all cases. There is no XOR edge because you are merely XORing data with itself. Jake --- Quote End --- True. Except that I am XORing my data with its DELAYED version. The above inversion procedures act as a delay. So that finally I XOR my data with delayed version of data. Such XOR will give me a 1 whenever there is an edge transition in my data. But this is not working on FPGA. Not sure why. I am working at 40MHz by the way.
